1 - 9 of 9 Posts
Anybody have any idea what this is and where it goes? It Gets hot when you turn the key to the on position:blink:.... We took the right side plastics off, and there it was...
And is there a way to post a picture easier than doing an attachment?
Welcome to the forums. That's the carb heater. It screws into the carb body on the bottom of the carb.
Discussion Starter · #5 · (Edited)
One more thing... how tight is that plug supposed to screw in? And why does the carb need to be heated?
And there is a couple of black hoses that come off of the carb that run into a connector and become one.... and that hose isn't connected to anything.... any ideas? i forgot to take a picture...
Just screw it in and snug it, it don't have to be real tight. I bet you don't have the collar that goes on it. The picture below shows the collar. You will need one of those, if you don't have it.
Is this on a 350 Rancher?
Yes it is a 2005 Rancher 350 2wd
OK, that's just a vent hose, it's not supposed to be connected to anything. Don't let it hang down. Run it up along the frame to keep it away from mud and water.
1 - 9 of 9 Posts
