I have a 2005 Honda rancher es, bought it with a bad motor, we rebuilt the motor put it back in side of the frame and now it will not start, Digital display shows first gear, cant get it into neutral, could it be the cable underneath the motor? Open to all suggestions.
chances are, you did not install the gear position switch correctly !. rear of engine, inside stator cover, gear position switch mounts to case with one bolt. the switch has a tang on it, the longest end of the tang rest OVER the letter N that you see on top of the switch, now put the case back onto the engine, see if you get a neutral light to start it ?.
Discussion Starter #3
