compare the new ones side by side to the old ones..if they are the same, then the new ones aren't going all the way in..either that..or you just got the wrong ones ??.Well got the old rocker arms kinda puzzled by something my rocker arm shafts are different sizes 1's a little shorter than the other![]()
Take the bolt out of the end of the tensioner. Take a tiny flat screwdriver and stick back in the hole and turn it clockwise. This will retract the arm on the tensioner. Hold it in this position until you get the tensioner bolted on. Once you get it bolted on, release the screwdriver and the arm will automatically extend and tension the timing chain. If you don't keep the arm retracted until it's bolted on, it will put too much tension on the timing chain.Well i have it all back together just getting ready to put Timing chain Tensioner back on and was wondering if there is anything particular i have to do to get it on anyone can help i appreciate it Thanks
No, the lines should be parallel with the head, but the cam lobes should be facing down. When you unbolt the cam gear from the cam, you can bolt the cam gear back on either way, with the lobes up or down. Make sure the cam lobes are facing down, then bolt the cam gear on with the lines parallel with the head and the timing mark on the cam gear at the top.Ahhh crap i can't remember now only thing i can remember from putting cam in, is i lined those 2 lines up on each side parallel from each other yea i messed that up back to the garage for me those lines should be up and down and i thought i was doin good (Thanks Helmut)
You're welcome. Don't forget to line the T mark up, so the piston will be at TDC.Ok now i got it thanks
