Hi: You bike takes 3.4 Liters (3.6 US qts. -- 3.0 Imp qts) Your bike has a dry sump.
Dry sump engines are a bit different from wet sump engines. On Dry Sump engines you will need to start and run the engine for five minutes or so -- then shut the engine off and wait for 2 - 3 minutes BEFORE you check the oil level.
Also if the engine has been sitting for any length of time you have to run it for 5 minutes, then shut off -- wait 2 - 3 minutes and check. Even if you have just changed the oil, you will need to run the engine.
This is because the oil tanks are all above the engine's oil pump. The oil is gravity feed to the pump. The oil will back feed through the pump gears and into the sump. The longer the engine sits, the more oil seeps back into the sump.
You have to run the engine so the scavenging oil pump will pump all the excess oil out of the crankcase and into the oil tank. Once the crankcase is empty of oil and the oil tank is full of oil, you can get a accurate oil level reading. Don't check the oil immediately after coming in from a hard run.
The oil level dipstick that screws into the side of the engine. Take the dipstick out. Clean all the oil off it and insert it back in the hole. Do not screw it in. Now remove it again and look at the lower end. The oil should be between the High and Low marks. If it is low, add some. If it is high, take some out
