1 - 9 of 9 Posts
I'd check to see if the crankcase breather tube under the tank is plugged or restricted.
Check the nipple behind the starter to see if it's clogged. Did this just start the excessive blowby? You might do a compression test.
Normally I don't smell oil unless it's been running hot and since mine have fans that just doesn't happen.
Discussion Starter #7
I only noticed it because it was on tick over but dripping onto top of engine from under the the fuel tank coursing smoke so I stripped it down and thats when I discovered it was coming from the breather pipe on the tranfer box
Discussion Starter #8
Update to the oil leave bolt out there was about 1liter of oil too much init so that where the problem was I have only had the quad 2 weeks so havnt got round to changing the oil in that thats why I didnt realise it was way over filled thanks for the help tho
Thanks for updating us. It's nice to hear about a solution. We all learn that way.
1 - 9 of 9 Posts
