I have a problem with my 2003 400ex. when i turn on the key, i have no neutral light, even though it rolls freely. I have power from the battery up to the key, but can't find anything past that. Is there a way to test the key switch to see if it is good or bad?? How can I test the neutral indicator, or bypass it just to test functionality? It has been starting fine up until yesterday, when I went to start it, pushed the button, and it turned over for about 1 second, then cut out, and have had no power since. Fuse is still good.
thanks
thanks
