1 - 17 of 17 Posts
I have a honda 2011 420 that never had any issues until now. It starts fine an idles fine even when I give it gas. But when I put in in drive to go forward it won't run. It keeps studdering out and wants to kill when I give it gas. But if I put it in reverse it runs perfectly fine with no issues. Can someone please try and help me possible issues?
HI: Your problem could be the fuel filter -- if you haven't change the fuel filter it could be real dirty and your bike is not getting the proper gas flow to run. The fuel filter is in the sub fuel tank -- located in front of the engine left side.
@Wsmill10
Please limit your requests to one thread per issue. Starting two threads concerning the same issue only clutters up the forums and causes confusion among those whom would help you. I have deleted your other thread. Thank you, welcome to the forums!
Which model Rancher do you have? What sort of repairs or maintenance have you done to the bike recently? Do you have a copy of the service manual? We need every bit of info ya got, even if you feel it isn't relevant.
Discussion Starter · #12 ·
Its 2011 TRX 420 IRS no power steering. Changed the bank angle sensor, the CDI, speed sensor, new spark plug and spark plug wire, new fuel filter, new air filter, and drained and changed the gas and oil
Ok, thanks. Try this first: Take the ignition coil off from the bike and use a small plastic brush (an old toothbrush works) to scrub the coil in warm soapy water. Clean it good especially around the spark plug wire tower connection and the power & ground connectors. Rinse and dry it completely and put it back on the bike to test. Don't drop it! Also just a reminder: Never unplug an electrical component while the key is on... voltage surges wreak havoc on the PCM and other sensitive components. Let us know what happens...
If the front brake lever doesn't go ALL the way forward, it will not let the engine rev in forward gear... it thinks the brake is still engaged. Try pushing the brake lever forward. Usually fixes the issue you mentioned. A little lubrication will keep it re-occurring.
1 - 17 of 17 Posts
