1 - 1 of 1 Posts
Model: 2009 Honda Rancher FA
It will fire right up with starting fluid sprayed into the intake. It seems like it’s not getting fuel. I replaced the fuel petcock and drained/cleaned the fuel tank. The old petcock stem rotted out in the tank and I figured it clogged the fuel lines. Fuel pump seems to be working just fine. I took it apart and it looks pretty clean inside. Tried to start it and still the same problem. I moved on to the injector. Seems to be getting fuel to the injector but the injector sprays just a little bit of fuel intermittently when i give it full throttle.
How much fuel should be squirting out of the injector and should it be a solid spray while giving it full throttle? Could it be something else going on? I don’t want to just throw parts at it.
1 - 1 of 1 Posts
