Thank you for allowing me to enter this forum.
My name is Bryce and I am a heavy equipment operator in the local 49 in Minneapolis Minnesota area.
I have a 2002 Honda Foreman 450es and am having problems with it shifting.
When I turn the key on the gear shift indicator flashes 3 times which should be the shift angle sensor from what I've read.
But when I try to shift the quad into neutral with the manual lever I get nothing, almost like something is not right in the transmission.
Any ideas on where to go next would be greatly appreciated. I am currently taking the shift motor off and going to check and lube the gears behind it and make sure none are broke. Thank you
