1 - 10 of 10 Posts
New to here,but need some advice...My 06 trx 350tm has always steered to the right.Have itp mudlites and right front is wearing faster than left.Outside edge is wearing like the wheel is tilted inward.Have checked toe in/out myself numerous times,as had my Honda dealer.No brake drag,either.Any ideas?
welcome to the forums! You may have a bent a-arm
Welcome to the forums. Since you and the Honda dealer have already checked the alignment, I suppose you have also checked for worn wheel bearings, balljoints, bushings, etc. Did you look for bent/damaged frame or suspension parts? Also, is the tire air pressure equal from one side to the other? That's all I can think of, but I've seen this problem with the Rancher 350 before and I couldn't figure out the problem. Maybe someone else will have figured out the problem and can help you more.
Hello all! New to the forum stuff too. Ronny I have an 06 350 as well, my wheels do the same except to the left! Ive adjusted my frontend and checked the tire pressure as well which all helped a little bit, I really think its a model thing. Do you have a lift kit??
No lift kit-everything bone stock except for Mudlites.Im kinda leaning toward a bent lower right front control arm.Cant tell by looking.
1 - 10 of 10 Posts
