Had to tow a heavy load this morning. Ok did'nt fill the 1000ltr tank to full, about 400ltrs & had to go up hill, still done the job. What I have is a tank & Honda generator for my electric submers pump with 2inch hose to pump water from a river into the tank (fills tank full in 4&1/2mins). this job is normally done using a tractor with a full load. In the front I have a little 2 stroke pump with a 1 inch hose to pump the water out to water my greens.
nice little set up..but..do you have a question about it ..concern ?
Discussion Starter · #5 · (Edited)
This is just a once off operation, would'nt pull this kind of weight to often, pretty hard pull on my Rancher, everything has it's limits, with almost 400ltrs (1ltr=1kg)of water along with the actual weight of the trailer you could be pulling well over 1/2 ton & have to go up hill, the low 1st gear is a good help.
