I changed my OEM. Headlight on my trx and i replaced them with aftermarket ones they work my quad turned on good then I turned it off then it wouldn't turn on and my headlights wouldn't turn on so I tried pulling the cord from the engine to turn it on manually and it turned on but when I put my quad in gear the lights would dim and I would put it back to neutral and my headlights were flicker on and off when I push the throttle they would just dim out and keep on flickering also when I turn on the switch the neutral light won't come up and won't turn on is it the battery or a cable or a fuse help please.
stay away from after market for the major part. might be a short with new lights. how does trx run without new bulbs? someone will be around directly, that knows more that me to help you out.
reply
if you make any progress, let us know, here at the forum. it might teach others. including me :smile
It sounds like you've accidentally wired in a short circuit when you installed your aftermarket light? If I were you, I would remove all of those modifications made to the wiring harness. Put it back stock. Check the fuses for a blown fuse or an overheated fuse socket. Then try charging the battery back up, start the motor and check the charging voltage (DC volts at the battery terminals) using a multimeter. If everything works at that point you are lucky, but don't be alarmed if something has fried... the light switch, ignition switch, regulator/rectifier, wiring harness, stator etc, any one of those can be fried if short circuited. Study up where you might have made a mistake in your rewiring job and try again. Solder your new joints if you cut any wires open. Check your work as you go and professionally insulate & waterproof every connection you make. Good luck with it... and welcome to the forums!
