1 - 12 of 12 Posts
Guys if I turn my Recon off and its not in Neutral it is a pain in the you no what to get it back into neutal to start it next time... When it is running I have no problem shifting any gears let alone back to neutral. Any ideas as to what this is or how to override neutral only start? Thanks for any help
I don't know if this is the problem, but I would try adjusting the clutch free play, first. If that doesn't fix it, you may have something bent. The picture below shows how to adjust it. This is from a Fourtrax 300 manual, but the adjustment is the same for all Hondas, once you find the location of the adjusting bolt.
I would have to agree with Helmut. I can't think of anything else that would cause that.
you mean like the shifter is physically hard to switch gears???
sometimes when i shut mine off in gear, i have to rock the four wheeler a little bit or else the gears wont grab. ill keep trying to kick it down gears but it wont catch any gears. once it catches it goes down fine.
other than that yea i would look into the clutch adjustment posted above.
i have to rock mine back and forth once in a while to get it into neutral. i have a 98 300 4x4 4trax.. esp when i turn it off when its in gear.
-- if the clutch needs to be adjusted to help this, do you tighten it or loosen the clutch?
i aint never messed with the clutch adjustment so i cant say.
i dont really think its a clutch issue tho what me and you are talking about. more so just needs tension on the drive train to catch. i dont know what causes this tho.
the reason i say i dont think its a clutch issue is because mine shifts fine driving it, if it was a clutch issue i would imagine i would run into issues while driving it also.
I cant seem to find it, does it still have it eventhough it is a automatic clutch?
Yeah, yours has it. It should be somewhere on the front of the engine on yours, since your engine is mounted longitudinally.
Yeah, what you guys are talking about is just a little slack in the gears. That's normal on the 300. Just rock it back and forth while you change gears when you're sitting still, but when you're moving, it should change fine.
1 - 12 of 12 Posts
