1 - 15 of 15 Posts
Bought a 05 TRX 350 basketcase. Guy said he redid the top end but " put it together wrong" and tore up a pushrod. Had all new parts including a cam...My only conclusion was that he forgot the lifters. This due to the way the rod was dinged and the marks on the old cam. So I put in all the new parts, adjusted the valves and during rollover with the plug out, I keep hitting a hard spot that requires a pretty good push on the wrench to complete the rotation. Is this due to the compression release?
Discussion Starter #5
Sheesh...I just notice that the cam gear was wobbling around !! Guess I might as well buy the flywheel puller.
I'd have to join Facebook to view the video....
Wild guess , problems with the crankshaft , the piston is cocking at the bottom of the stroke , it tore up the upper rebuild that was done back when cause it needed a connecting rod but didn't get it
Discussion Starter #12
Except the crank and piston work beautifully. No wobble or lateral play at all. That would not explain the play in the cam gear. Look at the video..
Discussion Starter #13
Great and powerful happy happy joy joy stuff !!! Looks like I didn't have the new cam fully seated !! Took a couple light taps. I didn't try that at first because the old one came out so easily. I can not see now obvious damage anywhere and am going to set it aside for tonight before something bad happens...Thanks again guys.
Discussion Starter #14
Dropped the engine in toady and with a $35 carb....she runs great. Now to start another thread on the drive shaft problem.
Thanks for the update, glad you got that issue fixed ( thumbs up )
1 - 15 of 15 Posts
