So I put the pull start kit on my 16 420 rancher a couple of months ago. Tested by hand starting and power, then parked in the garage for a while waiting for deer season. Deer season is here, fired it up, let it idle and now is howling from the rear bearing next to the pull start. Remove pull start, idle for a bit and the pull start pulley is warm. Bearing not getting oil. Is it possible to install the oil seal to far in and block an oil passage? I'm going to uninstall and remove the seal and go from there, any other opinions
