1 - 20 of 23 Posts
I just bought some new handlebars for the bike and I decided to accommodate it with some fresh grips. Any brands you recommend?
Oury atv grips, soft large square blocks best grips i have ever used,
I thin I have O'neal they are ok but thats all the dealer had and I needed some at the time
I have heard that spider grips are pretty good. I think Im going to settle with those.
I went on their website and read about their "shock absorbing" grips. Can anyone confirm of this being true?
I won't say I notice less vibration because of the grips but they are the only grip that I have used that actually get more tacky after use.
Discussion Starter · #9 ·
Discussion Starter · #11 ·
Sweet. I was planning on buying one but the price seemed to throw me off. Are tether switches pretty hard to install when it comes to the wires?
Should be pretty easy to hook up. I think it just hooks to the hot wire going to your ignition coil.
Discussion Starter · #14 ·
From what I have read, you just hook up one wire to a wire leading to the ignition, and the other is grounded. So I guess you just tape or wrap the other wire around the frame so it touches the metal?
Discussion Starter · #16 ·
That might be a good idea. What are some good tires for racing? I hear holeshots are some of the best.
Maxxis Razr2 is the best desert tire out there. IMO the Holeshots are really heavy, and the ones that are not heavy wear way too fast. I will not run anything but the Maxxis Razr2. My last set I bought the standard 6 ply razr, no comparison.
Discussion Starter · #18 ·
How would I get my racer number? Do I have to call them and ask them or register and then I'm assigned a number? Do I need to buy number plates?
Discussion Starter · #20 ·
Would I need to get number plates for the quad then or would they provide something?
1 - 20 of 23 Posts
