1 - 2 of 2 Posts
i have a kinda like a knocking noise on the right end when i'm drifting and i was wondering what it might be could it just be my right end tire lug nut needs tighten? i have no clue i was ridding all yesterday and right before i put it up i heard and it was 9pm and i'm going to look into today just was to tired to look into it....so i thought i would give a shout out and see what you guys might say it might be or to look for....thanks! p.s. i'm also looking for a seat for this with the latch on it and lower right a-arm too... thanks for all guys help in everything i asked so for ....you have help alot!!!!!!!!!:happy:
It is our pleasure to help out. Jack you quad off the ground and grab each front tire and see if there is any lateral play in the ball joints, check the a arm bushings, also grab on of your rear tires and see if you can make the axle wiggle. Could be the rear bearing has some play in it or the ball joints or the bushings. Those would be my first guess.
1 - 2 of 2 Posts
