Would you like to gain 4+ inches in the front for almost free?
step 1-Remove your front rims.
step 2-remove the tires off the rims.
step 3-take a nut and bolt with two orings and seal your current valve stem hole.
step 4-drill out a hole on the opposite side of the rim and use an older screw together valve stem(car style) about $5ea.
You will not need to fool with the shock location and the only reason to mess with the vale stem is to clear the brakes.
I bolted the wheels on and it was wide and took 10 min,lol.
It will work fine for wide on a budget.
I may do this when my new wheels show up and do a write up.
