1 - 9 of 9 Posts
I have a 2011 Honda rancher 420 on 27” tires and when I get down in deep soupy mud it bogs and I was considering 25% gear reduction and more aggressive tires, I’m looking for info, pros and cons and any general information about instillation, thank you!
Moved your thread to the gear reduction section :)
Anywhere in the region of 25 to 30% will be fine on an aggressive 27” tyre. You shouldn’t loose to much top end and it will give you that low down power back that you loose with a larger tyre.
I thought the gear reduction was only available in 25 and 69%
Not sure for a rancher, search this sub section, I’m sure I posted a photo with all available GR’s made by Jeremy Lee at reduction boss.
Reduction Boss makes 6-8 different sizes of reductions for the 420.
Reactions: SamUK
28 and above I would recommend a 69% GR.
1 - 9 of 9 Posts
