2007 420 4x4. I have a 2" lift and a 2" stretch. I'm wondering what I would need/look into getting to be able to solidly run 30" tires. Blew the seals on my rear end so it needs a rebuild anyway, and I want to do a reduction while it's open. I don't know anything about gear reductions and the science behind it, so please help.
Ok. I gotcha! Yeah I know trucks but kind’ve oblivious when it comes to atvs. A 35% is good for what tire sizes? Obviously 30 because that’s what I asked about but any bigger?
Depends on the tire really, and what you ride in, 30” is pretty well bang on the right size for it where it won’t matter how thick the mud or how aggressive the tire. You could still run 28’s it would just be a bit slow, or you could move up to a 31-32 but then you’d have to worry about the thicker mud and not being able to move the tires. 31” skinny outlaws you’d probably be fine, 32” assassinators youd probably want to move up to a bigger reduction, I know there is a 69 but I’m not sure if there is anything between 35 and 69 available. Personally I’d rather keep the reduction down a little bit and try and add some power to the motor to make up for it just so it’s not like driving a farm tractor between the mud holes lol
Ok! I actually have 30” silverbacks that’s I’m about to get wheels for and with my rear end issues, im just going to do a little work now so I’ll have less issues in the long haul. As for what I ride in, I refuse to sink it completely in water even though I have it snorkeled with the radiation relocated, but I am not scared to put it in a mud hole. Outside of a mud hole, some trails between mud holes is what I ride on. And by no means do I need to be going 60mph. My plan was like a 29.5-32” tire, but I think I will stay with the 29.5 or 30”, I was just curious on what sizes the reduction is “ideal” for. Thank you for your help!
Hey PAC, I just acquired a rancher with a stretch 2 or 3".
Have you had any driveshaft issues with your stretch? anything I should look out for?
I stripped my axle splines already on 28's what kind of parts have you destroyed with those big 'ol 30's?
