2001 trx450es, the Gear Position Indicator (GPI) on the instrament cluster is no where to be seen. Has anyone had or heard of this problem before, and what if any was the solution? Would purchasing a new cluster fix this issue? Another note, the problem does not effect the shifting of the ATV, that works just fine. I purchased this ATV with this problem so I don't have any idea when or how long the GPI hasn't been showing. All the other readings on the cluster work just fine.
Thanks!
Thanks!
