Hello
I own a 2007 Honda Rancher TRX420 TE. On the rear axle, between the gear case and axle nut there is a collar. Between the collar and axle nut is a sight gap about 1/8 inch wide. there is gear oil that is coming out that keeps it wet, but it"s not dripping. I'll wipe it away but when I take just a very short ride it comes back.I've downloaded the manual but can"t figure out if I can turn the axle nut one way or the other to close the gap or if there is some other way of correcting this. I'm not even sure If this is a serious problem or not. Thank you
