1 - 9 of 9 Posts
Just chnaged my front and rear differential gear oil and noticed the oil I used is Valvoline SAE 85W-145. Owners manual calls for SAE 80. Do I need to start all over?
Also didnt realize front Gear case on engine uses 10W-40 motor oil. I inserted the Gear oil in there also but realized my mistake. What could have happened to the gear case by using the gear oil vs. the 10w-40 motor oil anyway??
I doubt that will hurt the diffs. I've seen a lot of people run gear oil in the front gear case/transfer case. I don't think it will hurt anything, because there isn't any pump or anything in the transfer case.
80w or..in your case ( no pun intended )..85w is fine..as for your transfer case..80w won't hurt it..it does call for 10-w40..but..seeing how it does not have any kind of pump..80w or 85w will be fine.
What is the -145 part of the gear oil I have? the label says SAE 85W-145. Is this like a multiviscosity gear oil that goes from 85W to 145W whatever that means?
Yeah, I think so.
don't know about the 145 part..if your concerned..put 85w hybrid oil in your differentals.
I thought it was like oil, the 10W-30 meant it flows like a 30wt in summer and a 10wt winter? Or is it that it flows like a 10wt and protects like a 30wt? don't remember for sure but the lube you used should be FINE. There was a guy here at one time that did tons of reading and research on oils and stuff not sure if he is still here.
Yeah, I think that works similar to way engine oil works on the ratings.
1 - 9 of 9 Posts
