Pod', is it necessary ? No . ------ if you do decide to use any kind of sealant , I would use only HondaBond or YamaBond and a very light coat ---personally I only use it on the clutch cover side to help hold the gasket in place , also if the cover has to be taken off again for some reason , I can usually remove the cover and not damage the gasket
