Welcome to the forums. I believe '88-'92 tanks are the same, but '93-up are made different, because they changed the frame. The '88-'92 had one big round tube that runs under the gas tank and '93-up has to small tubes.
thanks yea it appears as though you cant make it fit, would a tank off a 4wd go on a 2wd?
It should, I think the 4wd frame and the 2wd frame are the same where the tank sits.
