I haven't driven it for a few months, so I'm guessing it probably eroded. I'll pick up a rebuild kit. The carb looks hard to get out. Any tips? Better to take out from the side or from above? Also, is there a link or parts diagram to order the tubing that comes off the float bowl.
guessing this is a trx350 rancher ?, ( you never said which rancher you have ? ), it's easier to remove from above. I would remove air box, vent line from right side cover from air box, loosen the band clamps at both sides of carb, unhook the heater line from right rear side from the connector. once you pull the carb up, remove the left black plastic side cover, one screw holds it closed, take a 10mm open end wrench, loosen the lock nut on the throttle cable right there on top of the black plastic cover, pull the throttle cam up, pull the cable out of the cam, twist the cable out of the carb. 14mm open end wrench, remove the choke cable cap, careful !!!..the threads are plastic. now you should be able to lift the carb out of the atv. get your hands on the service manual, best tool you will ever have
