Here's the pic finally up.Hello. My first post. I have 2004 trx350 which replaced the s wingarm bearings on. I have gap on the right side between frame and Swingarm. Is my frame bent and can I pull closer with a cargo strap or something? It's about 1/4 inch.
Its apart. The right bolt is a few thou thicker than the left bolt. The left bolt fits the bearings inner hole perfectly. The right bolt is tapered marginally and does not fit all thé way. This of course pushes the swingarm left when tighting bolts. I figure to take the right bolt down to the left bolt dimensions on the part that goes into the bearing. All bearings and races at correctly seated.Here's the pic finally up.Hello. My first post. I have 2004 trx350 which replaced the s wingarm bearings on. I have gap on the right side between frame and Swingarm. Is my frame bent and can I pull closer with a cargo strap or something? It's about 1/4 inch.
Both, rust and aftermarket bearing but the bolt is a few thou thicker than the right bolt. Looking back on it, it was stuck on the original bearing and had to use a puller. Last owner was a 16 year old who claimed he changed all bearings himself. He also didn't use seals or grease on bearing either. I suspect heat expansion in the bolt. This rebuild has been a process of "discovery".Are they aftermarket bearings? That could explain the problem... Or do you have a rusty pivot bolt? Both pivots should measure the same pin diameter, the bolt with the locknut belongs on the right side. I've never seen OEM bearings that did not fit the pivot bolts.
hardest part is getting the inner bearing races out of the swing arm, other than this ?, its pretty easy in my book..lol. dont worry about the large lock nut on right side, all you need to remove is the 17mm allen bolt from there. I find it easier to remove the inner bearing races by drilling a hole through the drive shaft side swing arm bearing. just run a 1/2 drill bit into the inside of the drive shaft opening, where you can run a steel rod all the way through, and hammer the inner bearing race out from inside, this is pretty easy.Fixing to redo my 03 TRX350 was it hard to get apart never worked on one like this b4
you did remove the inner bearing race before you installed the new bearing.....right ???.Here's the pic finally up.Hello. My first post. I have 2004 trx350 which replaced the s wingarm bearings on. I have gap on the right side between frame and Swingarm. Is my frame bent and can I pull closer with a cargo strap or something? It's about 1/4 inch.
Yes. New race, bearings and grease seal.you did remove the inner bearing race before you installed the new bearing.....right ???.Hello. My first post. I have 2004 trx350 which replaced the s wingarm bearings on. I have gap on the right side between frame and Swingarm. Is my frame bent and can I pull closer with a cargo strap or something? It's about 1/4 inch.
