Hi anyone! I've posted about this several times. I've developed a short SOMEWHERE - been tracing wires. At any rate, here's a picture of the fuse block. The fuse to the far right (25A) blows immediately when I put one in. No documentation (book, etc.). What does this fuse control? I have no neutral/temp light - other lights work. It was fine before it just wouldn't start with the electric starter it would just "click"; it would put start fine. Then, the fuse blew. I installed a new solenoid and even put the old one in just to check. The fuse blows immediately (with the key on or off and even removed. There is constant current running through that circuit but the battery doesn't seem to drain.
