1 - 11 of 11 Posts
Hi All I am a proud owner of a honda 300ex.its a 2005 has spacers back and front,kenda rubber allround.It has a pro-circuit t04 pipe and has been jetted by honda.Im in kzn in sa I ride with bigger bikes like the honda 400ex and fall behind on outrides
is there anything I can do to improve my topspeed cause the take off is strong but my top end needs a boost.please help with any tricks to tweak my pride and joy up...
Welcome to the forum. Probably the easiest and cheapest thing would be to go up one tooth on your front sprocket, you'll gain top speed but loose a little power out the hole.
Agreed with ^^^^ or get you a TRX 450r and blow them away!!!
Welcome to the forums.
A K&N or other high flow filter may help, ditch the air box lid, too. You can definitely tell the difference, but it won't put you out front of a 400ex. Are you running a complete exhaust or just a slip on? If its just a slip on get a head and mid pipe for it. Also, get a cam. You'll notice a huge difference.
you can go up one in the front and have your chain eat through your casing or you can go to a 36 in the rear and have your chain tight as a banjo string because the adjuster cannot give enoguh slack
Get a new chain!!!
You can add links to the chain with a couple master links and make the chain long enough.
Well you could always change your gearing up a little and put a good intake and filter on it that wont put you ahead of a 400 but its cheap and will give you more bang for your buck than a full exhaust system
1 - 11 of 11 Posts
