So my '02 350 has an issue. First i noticed fuel coming out the carb overflow so i assumed the floats were sticking. Pulled cleaned back on and still leaks once the machine is warm.
However the weird thing is the fuel tank is building pressure. Enough so it is pushing fuel out of the breather tube valve on the fuel cap. Not enough it pools up but enough that i can smell it and if i touch the valve its defiently leaking up there.
Why is the fuel tank pressurized? And are my floats really still sticking after cleaning or is the tank pressure causing fuel to leak out of the carb?
