new guy so Hi to all. picked up 02 450 foreman with only 100hrs. left front wheel toed out. are these machines setup square or should i set to slight toe in or out for handling? no obvious thing bent but porbably sitting because previous owner dropped it off truck or hit something hard with plow on it, as push tubes have hit back of plow hard. have not pulled off body to look for anything bent on frame. any weak points you guys have found over time i should check: shocks or shock mount brackets, certain joint in frame or anything? handle bars & body seem to sit off center & down slightly to right, makes me think it was dropped on left front. couldn't find anything in forum search, any suggestions appreciated!
thanks jw
[email protected]
thanks jw
[email protected]
