Searched forum but couldn’t find exactly what I am dealing with? Have a 2002 Rancher 2wd. Its a garage queen, used during hunting season never submergered no corrosion issues.
Developed a squeal in the front end this season and suspected debris in drum? Squeal comes and goes intermittently. Pulled drums and they were found to be like new inside. The left side did have brake dust build up as compared to right but nothing to alarm me.
Here is the question? With the wheel/tire removed the drum is pretty tight to spin. Unlike a trailer wheel you can’t free spin the drum you almost need two hands to rotate it. There is no free spinning what so ever. I don’t hear anything rubbing, nor feel anything other that smooth resistance. The rubber seal along the outer edge of the drum is like new, still has a light colored grease in the seam. The bearings feel like new, and the resistance seem to occur once the drum is pushed on all the way and the rubber seal is in contact with the brake plate. The shoes are fully retracted.
Is it normal for there to be resistance as described? You can turn it with one hands but it’s not an easy spin by any means. The plate and rubber seal is clean like new. Wondering if there is a special lube or something that should be applied to the rubber seal surface? It has done an amazing job of keeping debris and water out of the brake assembly but wow! What a power robber is has to be. Kinda like someone is riding the front brake.
Thank guys for any info on this one.
