I have stock 12 in pioneer rims on my bike if I put the disc conversion will I have to get new rims r will the ones I have fit
need more info. what model atv? and are the stock pioneer rims aluminum? or steel?
As long as they are steel wheels you should be fine, I’ll assume that you made sure the brake kit fits your machine already otherwise.
Discussion Starter #4
I did not buy them yet but everything I researched they fit on the bike what is the difference between it fitting with steel and aluminum
The aluminum rims are thicker, therefore the ID of the wheel is smaller. There is a slight interference with the calliper for the disk brakes. I wouldn’t doubt you could shave some material off the calliper and make it work, but that’s not technically by the book lol
mac102004 The aluminum rims are thicker said:
Grinding on the caliper is by the book now , at least the instruction booklet that comes with new SuperATV kits , which says to grind the corner of the caliper with aluminum rims
I use 1 inch wheel spacers on all of my disc conversions , with spacers it is no problem
So with a 1 inch spacer it will work without grinding
I don't know what atv you have ............... from personal experiences , I know a 1 inch wheel spacer works with aluminum rims and a SuperATV disc kit on a 1st , 2nd or 3rd TRX300 2wd or 4wd , or 1st or 2nd gen TRX450S or FM
About this Discussion
4 Participants
fishfiles
Honda ATV Forum
Full Forum Listing
