I have a 1991 TRX 300 that won't go into neutral. I used it to
drag my snowmobile into the shop and after that it won't shift down
into neutral so now I can't start it. I tried rocking it and shifting at
the same time, nothing. It seems I can shift it up and down like
first gear to second to third and back down but when I get back
down to first gear it won't shift down from there. At that point the
manual foot shift lever feels like its stuck in place as it won't move
downwards.
your gonna love this..lol..your shifting lever arm..which is inside the case..probally has either a bent shift arm..or broken shifting arm wheel..or all the above..your gonna have to tear into the case..to get to the shifting area..i'm putting my money on thats your problem..i can't remember which side has all this in it..but if you go to bikerbandit.com..you can pull all this info up..and it will show you which side has it..thats if you dont have a book on this model :).
ATV won't go into neutral
was wondering if the recommendations suggested regarding the shifting lever arm being bent or the shift arm wheel broken fixed the problem. Also the website suggested is not correct on the reply to shadetree. It should be bikebandit not biker.
Hi Dawn and welcome to the forums!
my bad..yer right..it should of read bikebandit.com <sigh>..lol
