Hello all,
I have a 90 Honda Fourtrax 300 FW that i was given, it needs tlc. The steering shaft bearing is toast. I have removed the steering shaft, and circlip but the outer bearing race is stuck. The manual says to remove it from the top, not much room or a straight shot at it due to the front diff. Any tips on removing it? The only thing i can think of is making a relief cut with a dremel then trying to pound it out with a punch. Or trying to press it out with a ball joint press?
Any ideas would be appreciated!
