my honda fourtrax 4x4 1999 seems to lost power,had carb cleaned, gas tank cleaned, when you throttle and shift it doesn't go like it use to,any ideas??
does it rev up..before you shift gears ?..if not..then your carb isnt cleaned right.. if it does rev up..and then you loose take off power..more than likely your clutch disk plates are worn...you may even be able to adjust the clutch before you decide to replace them.my honda fourtrax 4x4 1999 seems to lost power,had carb cleaned, gas tank cleaned, when you throttle and shift it doesn't go like it use to,any ideas??
it's easy to remove..get a 14 mm open end wrench..un screw it off..very easyI'll try to get a more thorough cleaning done again, the only challenge I see is the connection of the choke cable at the carb and how to disconnect it at the carb. thanks again
Just use a wrench to unscrew the choke cable and it pulls out with the start enrichment valve on the end of the cable.I'll try to get a more thorough cleaning done again, the only challenge I see is the connection of the choke cable at the carb and how to disconnect it at the carb. thanks again
lol helmut..you are fast with them pic's..lol..but..i don't need pic's..i've got them all stored in my head from 12 years worth..lmfao...but..great work bro !Just use a wrench to unscrew the choke cable and it pulls out with the start enrichment valve on the end of the cable.I'll try to get a more thorough cleaning done again, the only challenge I see is the connection of the choke cable at the carb and how to disconnect it at the carb. thanks again
Uploaded with ImageShack.us
Yeah, I don't need pictures either, but it probably makes it easier for everyone else and it's easier than typing all that.lol helmut..you are fast with them pic's..lol..but..i don't need pic's..i've got them all stored in my head from 12 years worth..lmfao...but..great work bro !Just use a wrench to unscrew the choke cable and it pulls out with the start enrichment valve on the end of the cable.I'll try to get a more thorough cleaning done again, the only challenge I see is the connection of the choke cable at the carb and how to disconnect it at the carb. thanks again
Welcome to the forums. Lots of people have had that problem. You can take the cable loose from the valve and try drilling a small hole down through the top of the valve. Then, screw a screw down into the hole so that the threads cut into the valve. Then clamp ViseGrips on the head of the screw and pull the valve out. Of course, you will have to replace the valve.I am trying to get my choke cable off and the choke valve and seat seems to be stuck in the carb. I can unscrew the plastic nut but the assembly wont come out, how the heck can I get it out now ive tried soaking it with wd40 but doesnt seem to be doing anything has anyone had this problem?
You should be able to pull hard on the cable and the end of the cable should slip out. The tip of the valve is made of brass and it should just break off where the cable hooks. Sometimes, the cable will just pull out and not even break the end off. You will have to replace the valve anyway, so it won't matter if it breaks. I believe that choke valve (starter enrichment valve) runs around $35.I cant disconnect the cable from inside the carb there is no free play what should I do cut it and start drilling?
Thanks.By the way nice wheeler in your profile pic.
