What do ou mean by not locking? Cant get it on enough to put the pin in or hub is wiggling? more info..pics
Sounds like you may not have it pushed up all the way did you loosen the lock nuts? don't forget to put the lock ring on the axle too!
Can you take a picture and post it? also the 250X were notorious for stripping the axle lock nuts.
You have to seperate them the inner will turn up towards the seat and the outer will turn towards the ground.
