1 - 13 of 13 Posts
i have an 05 350 with electric shift any way it wont shift and the n is flashing any one got any ireas on how to fix and what is wrong im new to atvs but am preatty good on general repair when i know where to start tks for the help scott
Welcome to the forums, I'm not much on uility quads but I would say you may have an angle sensor issue go to the manual section of the forum there is a procedure and listing of how to read and determine the codes.
Have you counted the flashes?
Honda 2002 and up ES and all Rubicon models use codes to identify shift and tranmission problems. The codes are different for each type/model so make sure you are following the correct procedure; ES models are listed first, followed by the Rubicon
First thing to check is the volage from the battery. It should be a minimum of 12.4 volts. Check all main and accessory fuses.
2002 and newer ES Models
If the gear indicator isnt flashing , you can manually interogate for codes.
1 Turn ignition to off
2 Place tranny in neutral
3 Put on parking brake so the quad does not move.
4 Press both shift buttons (up and down), and hold them in, while turning the key to on. Make sure the N appears for gear position. Release the buttons.
5 Wait 5 secs,and then press both the switches again.and hold them in for at least 3 seconds, then release the switches.
5 The problem code is displayed by a certain number of blinks “ - - “ on the gear indicator, which indicates the problem code by the number of blinks. If “N” (neutral) stays ON on the position indicator, the retrieval process was not correctly performed. Repeat the procedures from step one at this time.)
6 When the problem code(s) displays, release the shift switches.
You should see “ - - “ for approximately 3 seconds then off, then the “ - - “ should flash, once for code one, twice for code two and so on. The engine control module (ECM) can store two different codes. If your ECM has stored two different codes, the first code displayed is the most recent and the second code is the earlier code. Write them all down.
7 To delete an old code, Press the switches when the code if flashed
No flashing, no problem.
The codes point to a system with in the ES. It doesnt necesarily mean the component is bad, but that theres a fault in that circuitry. Could be a disconnected wire, shorted wire, or high resistance in the wiring, or it could be the component. The service manual gives a process of trouble shooting, to nail down where the problem is if it is a wiring/connection problem.
1 flash, euc (writing and recording circuit) , probable faulty part ECU
2 flashes ES shift switch system (up and down) probable faulty part, shift switch, related wiring harness, or ECU
3 flashes,angle sensor system, probable faulty part, angle sensor, or incorrectly installed,related wiring, or ECU
4 flashes,gear position switch system, probable faulty part,gear position switch or related wiring or ECU
5 flashes,ECU motor driver circuit, probable faulty part,ECU
6 flashes, ECU fail safe relay circuit, probable faulty part,ECU
7 flashes, ECU voltage convent system, probable faulty part, ECU
8 flashes, angle sensor system, probable faulty part,angle sensor, or control motor, or related wiring, or ECU
9 flashes, angle sensor system, probable faulty part,angle sensor(short or open), or related wiring , or ECU
10 flashes, ignition pulse generator system, probable faulty part, ignition pulse generator or related wiring
11 flashes,speed sensor system(vehicle speed), probable faulty part speed sensor or related wiring or ECU
12 flashes, gear position switch system, probable faulty partgear position switch or related wiring, or ECU
Welcome to the forums. Check your battery first and make sure it is charged.
Welcome to the forums!!!!!!!!!!!!!!!!
man i was hoping to see the repaired comments cuz im lookin at buying a new atv and kinda curious how much trouble these trannies are :mellow:
go to docsatvservice(dot)com and he has a bolt on hand or foot shifter for the ES models. i have this on my foreman 450 and when i get into the woods it gets me out. And on docsatvservice(dot)com he has a module that bypasses the ES wirings and is direct. i put that on my foreman and now i can go through mud and it will work and the ES has not given anymore problems since. his number is 601-659-9931
1 - 13 of 13 Posts
