161 - 180 of 197 Posts
My 2014 Rancher 420 ES will occasionally not upshift while driving around. At first I thought it might be a bad switch or contacts within the mechanism but I'm not sure. I know there is an angle sensor that can throw things off. I'm getting no check engine light and it works the vast majority of the time. I can't seem to reproduce it. The ATV only has about 80 hours on it and has seen little use. Any suggestions on narrowing this down? Clean and dielectric the connections? Replace the up-shift button? Replace the angle sensor?
I should add that when it won't upshift, there's no action whatsoever. It's like I didn't press the button at all. It's not like it tries but fails. I just does nothing when I press the button. After a few moments, if I try again, it will upshift fine.
@kenn, first thoughts are a bad connection in a harness plug or possibly an old & weak battery. If the ES system has never been prepped yet it should be done as soon as possible.
Fish/Retro
The SHAFT reduction gear (round gear) that doesnt have any specific position when i reinstall that correct?
i marked the shift reduction gear (triangular shaped one) where it came off the shaft so im going to put that back on where it was.
Any tricks/tips for putting those components back together once i get this bearing racer out? (i picked up dremel carbide cuter)
https://www.lowes.com/pd/Dremel-Tungsten-Carbide-1-8-in-Cutting-Bit-Accessory/1209475
Fish/Retro
Correct.
The lower triangle shaped gear only fits one way on the splined shift shaft. It will be centered with the round gear... see the service manual.
Clean everything up good, clean the old grease out of the support bearings then repack them with synthetic grease using a finger to push grease past the metal shields on each bearing until they are each completely full of syn grease.
Inspect each bearing to make sure they are installed squarely in their bores. Crooked bearings are common on ES bikes and they must be corrected.
Coat the gears liberally with syn grease and coat the o-ring type gasket with either syn grease, silicone o-ring grease, or apply a thin coating of RTV gasket maker if this is a mud bike. Tighten the bolts in a criss-cross pattern in 3 steps and don't overtighten them.
Grease the o-ring & line the flat up on the angle sensor with the flat on the shift shaft and snug that down carefully. Don't overtighten it.
Dielectric grease every harness connector pair on the bike.
Disassemble, clean & service the shift motor.
There are links to posts above showing how to do that job.
Feel free to question... take your time, be thorough and have fun with it.
Fish/Retro
Correct.
Well... she's all put back together. Hardest part was being patient enough to slowly grind down the bearing racer. Finally i punched through and took a flat head and pried up on the racer and it came out. Cleaned that entire housing out with carb cleaner, dried it. Then started pushing syn grease in the bearing like it was my job. I put on a pair of latex gloves and got a wood paint mixer. Put some grease on it and just kept smooshing it into the bearing shield for a solid 10 mins. Did the same for the rest of the bearing.
re seated all the gears, rtv, dielectric on the connector (brand new shift motor) Went to shift it... wouldn't get into first. I tore it back down rechecked i put the spindle gear in the right location. Then i realized it was jacked up and seated back on an angle. I need to rock it.
So i put it back together, again. put the wheels back on, took it off the stands. Rocked it back and man i dont think i ever heard an ES shift so smooth and quiet.
Glad its done, but it was fun. I may tear down the 250 and do the same lol.
Thanks for all the advice.
glad the dremel worked, an the carbide cutter.. i have to ask, if ya had the 2-speed, dremel, or one of better class. i got the 2 speed once, by the time i got to using it, it was already out of warranty. only the high speed worked well. it was sold at lowes, but didnt cost much. i think $29-$39, on sale..
sometimes ya get what ya pay for.. :icon_censored:
Buenas tardes amigos!!!Les cuento que solucione el problema, desarme la botonera del lado izquierdo y limpie los contactos con limpia contactos en aerosol, retire hacia atras las gomitas de los 2 pulsadores y lo rocie de con aerosol mientras los pulsaba asi penetraba el producto , luego volvi a armar todo y funciono todo bien.
Gracias por todos los consejos que me dieron, espero le sirva a alguien mas con el mismo problema.
{translated) Good afternoon friends! I tell you to solve the problem, disassemble the keypad on the left side and clean the contacts with clean aerosol contacts, remove the rubber bands of the 2 pushbuttons back and spray it with spray while pressing them so it penetrated the product, then reassembled everything and everything worked fine.
Thank you for all the advice you gave me, I hope it serves someone else with the same problem.
Gracias por compartir con nosotros cómo lo arreglaste @pablocuello!
my 01 450 es shift went out a few years back. I have a foot shifter on it which works fine, i use it just for plowing so basically i throw it in second and just stay in that the whole time. I recently put on a brand new shift motor and angle sensor. Same exact thing. I took apart the control buttons and cleaned everything. Still same problem wont shift. anything else I can try ?
thank you for any info.
I know this is an old thread... but I can't thank @kentco enough for this fix... My 2007 Rancher has 2900km on it. When it was cold it would not shift into 3rd, had to let it heat up a bit but after hot it was OK, but stil not as smooth as I wanted. So.. I decided to take apart the casing like Kentco advised.. Removed the old grease, slap some all temp lithium grease in there. Now it can shift to 5th right after being started... Amazing!! Only thing I can recommend is to not take off the allen screws off the shift motor (I had a difficult time putting it back together). In the manual it mentioned to put some gasket sealant around the casing, which I brushed a tiny coat before putting it back together.
Many of us have Electric Shift (ES) models. In fact, Honda sells approximately EIGHT times as many ES models for every foot-shift model sold. The ES models are very reliable. But, because of the number of ES machines that are sold and owned, it sometimes seems that there are more difficulties with ES shifting than with manual shifting. Unfortunately, there has been one problem with ES shifting that has affected many ES owners at one time or another: The problem is that, at times, when you make a shift (up or down) on an ES machine, the shift is not complete. You can hear the shift motor trying to make the shift when you press a shift button <->, but no shift occurs and, at times, you receive a - - - display. The problem occurs even more often when it is cold outside.
Fortunately, the answer/fix to the problem is really very easy! The problem is caused by very heavy, stiff, gummy grease that was installed in the shift motor gears at the factory. Once that grease is removed and replaced with a different grease, you'll be back to shifting normally! So, here's how you replace that grease: Remove the shift motor and gears (all one piece) from the lower front of your engine. There are normally four 10mm bolts that hold it on. Once you have it loose and off, you will see that in the gears, there is some very thick, gummy, stiff grease. Clean out all of that grease. (You can use a solvent such as paint thinner to get it all out). When cleaning the grease out, do be careful not to disturb the position that the gears are in. Once all the old grease is out, replace that grease with a generous amount of ALL-TEMPERATURE, WHITE LITHIUM GREASE. (That grease is available from any auto parts store.) After you've put the new grease in the gears, reassemble the shift motor/gears back onto the engine/transmission. Snug up the 10mm bolts, but don't over-tighten them. You should now be good to go!
Note.... I have brought both this problem, and this fix, to the attention of Honda Powersports. They have been very responsive to me and have assured me that they will not only let their dealers know of this fix, but that they will revise the grease that they put into future models.
I hope this helps you! ..........Ride Safely...........Have Fun!
I have a 2016 Rubicon DCT, my electric shift motor keeps going out, I put one after the original one gave out, I do sand/mudding mudholes/waterholes riding and this second one is starting to give out. It will ride for about 20 to 30 mins and then will stop shifting, -- appears and I notice the shifter motor gets really hot, I went on 3 rides only with the new electric shift motor?
will this problem cause the 3 flashing "N" code?
Bike will not shift up or down gears with buttons tested countinuty at the wires for shift motor all ok!!! its a 2016 Honda TRX420 FE!! new shift motor an angle sensor fitted an new ECU tested on bike an all ok!! tested plug on shift motor an power getting to it but no ground at it? any ideas?
Hi! I have a 2015 Honda TRX500FA-5 with Electric Shift. I've been having problems with my ES. I've had it to the dealer and they told me it was the battery (even though we knew it wasn't), they replaced the battery and we picked it up. My engine light is flashing (it always is because of the O2 sensor) and it's flashing code 23. I don't think code 23 has anything to do with my shifting issues. What happens is when I'm driving and I go to shift, sometimes it will shift fine, but once it decides to stop shifting, whatever gear you are in, you are stuck in that gear. There's no shifting up or down. Sometimes it will throw the --- on my screen. The only way I can get it out of that and back to neutral is to shut it off and try again the next day. When I switch it into D (keyword is WHEN), it will run, just won't change gears. Please help!! Thank you :)
Thank you for the post i have of 09 420 and it just started doing this but now I wont have to deal with a Dealership
2015 Honda Rubicon 500
I am having this issue with my 2015 Rubicon, I am going to make a manual conversion kit for it but I will try this first and hopefully it will shift better until I get around to making the manual foot shift kit. Thank you!
Hi, So I watched a you tube video, and it said you can take the gears out of the shift motor and make the floor shift easier to shift. My shift motor is no good so I have to manual shift it, but its so hard to shift. Is it ok to do this? Has anyone ever done this? Please give any info you my have. I have a 2004 Honda Rancher ES 350 Thanks
