Hi I have a 2007 Rincon with the FI light flashing. It flashes 9 time and starts flashing again. Would anyone know what that code means and how to reset the light so it doesn't flash. It just started on the weekend while I was driving. The engines still runs good.
I also have a problem with my transmission. Sometimes it shifts properly and sometimes it shift at high RPM for no reason.
Thanks in advance for your help
BuckT
Welcome to the forums...Did you check out the shifting troubleshooting section,or the code reading section in the free manual you downloaded???
I don't know what the codes are but i would give the plugs on the tranny a wiggle test and while U have them unpluged check them for corrosion/ water and use some die-electric grease be for pluging them back in.
Discussion Starter #4
Hi,
Thanks for the response.
I did check the code in the manual that I downloaded from this site and, I think that it's the IAT Sensor. I will be inspecting today.
For the shifting of the transmission it doesn't give me a code. I will check the connections and coat the connectors with die-electric grease. I have installed a Big red gear kit a few weeks ago and seam that the transmission been shifting eratic since then. My boys have been using it more than I did since I installed the gear kit. I look in the manual to see if I can adjust the shifting range speed and I didn't find any adjustment.
To reset the light I don't understand the procedure in the book without the pocket tester.
Would any one know how to reset the light before I short the wrong wires and fry my computer?
Thanks
BuckT
