I purchased a used 2014 Rancher 420FM last year. I posted the other day about a exhaust pipe leak at the cylinder. I will be taking the quad to my mechanic next week for him to replace the crush washer to see if the leak will stop. Tightening the bolts helped the leak a lot.
I found another problem yesterday. I purchased a new seat, put it on and rode for about 4 hours, stop and go. I noticed my left upper leg was getting very warm towards the end of the ride. While taking the seat off I found that the left plastic tab is melted!!!(where it hooks to the frame). It's not the entire tab but enough that it's obvious something is going on to cause this.
This plastic seat tab is located above the exhaust.
The odd thing is that the OLD seat has only one tiny area that looks like it got too warm, but nothing like what has happened with my NEW seat.
What is causing the increased heat?? Is it the exhaust or the engine?? Could the 27 inch tires all around be causing this??
The only engine work done was rebore and rebuild of top end due to smoking and done my first rip-off mechanic. My new mechanic readjusted the valves and told me "they were not set right." It runs GREAT but I checked the spark plug last week and it was black with soot. It's running too rich from what I can tell.
I have ridden less than 30 miles since the top end was rebuilt. I ride mostly at low speed due to the terrain. Oil has been changed twice. New oil filter and air filter. Clean radiator with new fluid and fan works. No error messages.
Please help!
Please help!
