got the clutch to pull on the rancher must have been stuck we had to adjust it all the in and out a couple times before it started working but the ES still will not work any info on the ES will be greatly apreciated
is the N flashing if so you need to get the code by counting the # of flashes or with the bike in neutral hold the up & down shift buttons turn the key on then let go of both buttons then push them both again for a couple seconds and release the N should flash count the flashes refere to repair manual for code(s) or call honda dealer for code.
