1 - 2 of 2 Posts
Had my 2008 Rincon 680 sitting for about 3 weeks, not on the trickle charger and went to go start it the other day and it’s dead. I turn the key and get a code of “3 slow blinks and 1 quick blink at the end”. Before I left it for the few weeks ran normal, nothing wrong. I tightened battery connections. Nothing. Put it on the charger and it said battery was charged. I tried just hooking up my led light bar to see if the problem could be a shot battery. No lights with just the light hooked to battery. I’m thinking of buying a new battery but wanted to check if anyone knew what the code was before I spend over $100 on the battery.
Thanks!
You can test the battery using an ohmmeter, or get the battery ‘drop’ tested at you local battery store. Your answer will be in the FSM which is available under sub-section ‘manual and schematics’.
1 - 2 of 2 Posts
