1 - 9 of 9 Posts
Jumped on the bike (in signature) yesterday and found out that I no longer need to use the reverse button/brake to put from N to R. This is actually more preferable for me. The only question I have is, does anyone think its a sign of a bigger issue?
Thanks
sorry. thought it would show in my signature.
its a 2012 420 foot shift.
agreed, reverse cable is frozen, allowing you to shift into reverse without pulling cable/lever.
So it has nothing to do with the button that needs to be pressed down as well?
Reactions: fishfiles
Mel , gives good advice , I have one of them cable lubers , I use the Yamaha cable grease comes out as a liquid and turns to grease , if the cable is really bad , any spray penetrating oil can that the tip accepts a straw can be used first till the rust and dirt is flushed out and working smooth and then apply the grease
1 - 9 of 9 Posts
