My quad has been starting this new habit of kicking over on its own as soon as I charge the battery up since it all ready drained the battery and killed it, is a new battery I had just put in. Also the quad is a 1998 Honda trx300ex. Can any one help me with some type of wiring schematic or a simple way to wire the quad up
I have the negative wire for the battery grounded on the frame right before the grab bar is that ok?
it may work there ?, but its best to be connected to the engine. reason: most times bolts rust, even engine mounting bolts !. so if you connect the neg cable directly to the engine with the starter mounting bolt ?, you will always have the best ground.
