Hi All
So I just had this happen with my Foreman 450...I went to use it yesterday and the battery was dead. Not surprising since I hadn't fired it up in a while, so I pull started it and went about my business. End of the day I parked it in the garage. Today I went to use it again, and I had a dead battery again. I was kind of surprised since it ran for quite a while and I would figure the battery would be charged. So I hooked up the battery charger and tried to start it, but it was indicating I was in first gear. So I tried to shift to neutral, so I could start it, to no avail. I can't even hear sounds like the tranny is trying to shift when I hit the shift button.
So I kept trying to get it to downshift to neutral, rocking the machine forward and back, no luck. Not getting any noise from the transmission. The battery charger indicated a fully charged battery so I took the leads off, and instantly my display went dark. I had no battery power at all, and couldn't run lights or the winch.
So, what do I have going on here? Obviously it sounds like I might need a new battery, but beyond that, why can't I get it to shift, even when I'm supplying full power through the battery tender, and why do I lose all power the minute I take the charger off?
Thanks for any help
Thanks for any help
