Hi Everyone:
I'm trying to get the electric start to work on my TRX300...I'm noticing there is no fuse..just the solenoid, new battery, CDI, Stator, regulator, all appear to be in working order...Is there a way to wire this without the inline fuse or fuses..missing wires..? Currently..I use the kickstart or just touch the hot cable direct to the starter from the car battery..runs well...Ignition key works..Lights only work when the engine is running....not sure about the start button on handlebars but the RUN switch works..so I assume the start button will function. I do have the service repair manual..but where there is no fuses, possibly missing wires too..not really sure....Where can I attach the small wires from the solenoid/starter relay?...I think one is ground and the other needs to be wired to the ignition circuit somehow?..Thanks
