1 - 2 of 2 Posts
I own a 2000 450 Foreman ES . Problem I had it was trying to shift but it wouldn't go in all the way so I took the shift motor out the brushes were very bad burnt so I put in a new shift motor I put in a new angle sensor cleaned up all the gears. Shift motor runs fine when it's out of the machine but when I go to put it in does absolutely nothing. I'm trying to read codes but can't get it to read codes? Not sure what to do any help would be appreciated
You will get better responses for your problem over at atvhonda.com
1 - 2 of 2 Posts
