there are ton sof links, LOL
heated helmet shields are found in snowmobiles for the past 20+ yrs and many even use them on street bikes in cold weather, they prevent the shield from fogging up
they DON:"T actually make any real heat to warm your face or likes however!
here is a link to some helmets that have them, MOST all came with all needed hardware to install on a sled, but NOT all
this means they come with a plug end that mounts to your battery and then all cords to your helmet!
Why should you get a snowmobile helmet with a pre-installed electric shield? Having a snowmobile helmet equipped with an electric shield can reduce fogging and ice buildup on the shield better than the dual lens shields. We have products from big name brands like HJC, Z1R, Scorpion and GMAX.
www.snogear.com
Most all modern snowmobiles however has fast easy plug and play set ups(meaning they already have a 2 SAE plug you just plug things into
as there pre wired on sleds for this option!
BUT if NOT< again, all you need to do is install one of these, and they come in a wide range of options for you to decide on what way you wish to have it set up
Shop the best selection of Snowmobile Electric Shield Power Cords & Keepers at Dennis Kirk for the lowest prices. FREE SHIPPING on orders over $89 – We Ship Today!
www.denniskirk.com
again, if you already have a 12 volt cig plug, its as easy as plugging in the right adapter into that socket and plug shield cord into and done!
here is a video on them installing on a snowmobile with a battery!(many sleds DON"T have a battery but still have a power supply, that can be used due to how little power they need!)
heads up both videos ain't the best, but should give you an idea, its real simple stuff here!
or
