The piston should be pushed in as far as it will go and with both pads in the caliper, there should be enough space in between them for the brake rotor. If the piston is all the way in and there's still not enough room for the pads and rotor, I don't know what the problem would be unless they're the wrong pads.when i try to put the pads in the caliper there is not enough space. should the piston be all the way depressed? it will not go down any further??
I'm not sure about the 400EX, but I think it is supposed to be flush. Most of the ones that I've noticed have been flush.helmut. does the piston go in as far as flush to the caliper? because mine is pushed all the way in that it will go. and it is not flush to the caliper. it sticks up a little.
Yeah, I use a c-clamp too. I forgot to mention that.k im gonna try the c clamp thanks
Mine would never stay adjusted on my 400ex. Everyone I know with a Honda usually removes themI've never had luck with any parking brakes. Never seemed to want to work right. Especially with the drum braked hondas.
Yeah, they will wear down if they need to. As long as they don't have the axle locked up tight, you should be OK.Good ill remove mine then too.. The C clamp worked! Well the pads are on and very tight. They will loosen after riding and burn away right?
